Chems
I've made some raised panels using the TS and now need to clean up the top edge. I've done one with a chisel, and could do the others the same way, but fancy taking the opportunity to make something to do it. Would a scratch stock of a molding plane be better suited to the job. Here is the waste left by the saw that needs to be cleaned up:
Here is the profile, the bit circled is the bit I want to clean up.
Any suggestions as to which would be better?
