Dalboy
Hope this is in the right place. Can anyone tell me if the blades from carpenter squares is any good to use as scrapers. I am looking to make some shaped ones for cleaning some carving work.
They are good for scratchstock blades, which work by scraping, so could be OK.twothumbs":rgmnc75g said:Hacksaw blades for small wortk?
xy mosian":18n54ufe said:Another lucky find was after making cutting edges from the blunt end of twist drills. If you grind an angled flat on the chuck end of a twist drill a satisfactory cutting edge is produced, for small work, tilted this becomes an easily sharpened scraper.
