SCHEPPACH Tiger 2000s wet grinder
jaro
1 Oct 2017
Limoux, France
Hi, I have a minor problem with this grinder - there is a rubber drive ring (140 dia x 20mm wide v 10mm thick) fitted on a plastic wheel, this is driven directly from the motor by a small dia metal spindle. I had mine tensioned very tightly and left for months - the rubber ring has developed a small dent on it's circumference, now when I use it, it gives a donk every revolution which makes grinding rather difficult. I wondered if there was some way of using heat to correct this. Thanks for any advice you are able to offer.
