Scheppach Tiger 2000 s
terence
27 Aug 2011
York UK
Can you adjust the tension on the motor drive shaft, when I am grinding planer cutters the grinder slows then stops even with small amount of pressure.
Terence
The Tormek I have does not have provision for this and relies on gravity ( the motor is free to swing on an arc) I think the Scheppach is a pretty blatant copy although a Jet clone that I had in for repair a few weeks back has a threaded knob to adjust the tension as well as some other nice features.
You should be able to see how your works by looking inside - maybe the end of the shaft and rubber wheel need a clean up?
Bob
