ossieosborne
In order to stem any rioting I don’t want to know about grinding/honing angles, honing guides v freehand or any other such malarkey.
I use various grades of abrasive paper for sharpening, temporarily glued to a slab of granite (blagged from local fireplace company) and also a smaller thick lump of slate.
The adhesive I am using at the moment is a spray-on Contact Adhesive (Toolstation I think). I find that, more often than not, I end up with slight ripples in the abrasive surface. It’s either my technique of applying the glue; too much, too little. I don’t know what.
I will admit that I haven’t tried using a spreader after spraying the glue onto the slabs.
Questions:
Is there a better type of adhesive I should be using?
How do you apply your adhesive to achieve a ripple free finish?
Oz
Questions:
Oz
