Lonsdale73
Is there a circular saw blade equivalent to Tuff Saws? If not, what are the preferred options currently? 216mm diameter, 30mm bore for both Mitre and Table saw.
Thank youTrevanion":1p2v9a6f said:I think Bennet Saws (https://www.ebsaws.com/) is the last circular saw blade manufacturer left in Britain now that Atkinson-Walker as closed down. Apparently, the Bennet Blades are very good although I've never tried them. The Atkinson-Walker blades were second to none and it's a true shame they closed down, you might still be able to pick up new-old-stock from somewhere though.
Swedex I believe are regarded as some of the best blades as well.
You can't go wrong with a Freud blade, they're very good for the price of them.
I personally use CMT blades from Scott and Sargeant and they are excellent with plenty of thick carbide on the blade to have sharpened again and again. S&S also supply OMAS blades which are very good.
I think everything else is pretty mediocre unless I missed some out.
