rafezetter
Troll Hunter
Hi - I've been having a bit of vibration on my triton circular saw; nothing major, and I've already lapped the mating parts of the spindle to the blade and that helped a bit, but it's still cutting wider than the blade should, plus the marks.
I've seen on NYW that tablesaws can fit aftermarket stabilizers to help with this, and wondered if it might be possible to have someone make ones for a circular saw, as I can't see any commerically available. - I would have to increase the depth of the bolt, but I don't think that will make much of a difference to the function, and might help tbh as with the supplied one; I'm certain the washer that's welded to it is not co-planar, which might be increasing pressure on one side.
Alternatively, how hard would it be to replicate the mating parts, but increase the surface area - currently they are 44mm dia and made of steel - one is flat, with a bevelled edge with a flat sided oval in the centre; the other is T shaped with a simple hole. Bother are fully removable from the motor spindle.
Of course, this is over engineering a bit, but is it actually a bad idea or could it have some merit? Is there anyone willing to give it a try - I can supply pics and caliper accurate measurements of the items in question.
