Sandpaper
gc
23 Oct 2009
Glasgow
Looking for sandpaper of 320/400 grit for finishing project but so much choice. Can anyone make some recommendations on type to use and where i can purchase from?
If this is for de-nibbing or 'cutting back' in between coats then, I highly recommend this stuff from Axminster. As long as you let the finish dry properly, it won't clog and it will outlast any aluminium oxide and standard silicon carbide (wet & dry) abrasives that I've used. You should also find it's good enough for general wood sanding as well. :)
I've just bought some of that in 400 grit, good stuff!
JH
