I'm looking at getting a 125 x 60 x 30 rebate block with 2 scorers top and bottom. Block is for rebating window frame and sash rebates.
If I put timber face plates on my original aluminium finger fence ( see attached photos ) then a false fence on top of that , this will be a combined thickness of 30mm.
I think I've done my sums just about right regarding the following points.
If I move the timber face plates and false fence back using the 125 x 60 block I can only get a depth of cut of about 8mm before the false fence backs into the spacer collar.
However, if I use a larger 150 x 60 block, with the timber face plates and false fence attached. I can get a movement of close to 22mm before backing into the spacer collar.
This seems a no brainer...... regarding which block to use....... but?
My Axminster WS1000TA moulder has a maximum tooling diameter above the table of 200mm and 180mm below. If I use the 150 x 60 would a clearance of 25mm be enough for proper dust and chip extraction? If not, then how can I attach a saddle to support the rebate cut on the aluminium finger outfeed fence?
Cheers.
Cheers.
