The problem with gadgets and woodworking is you can get obsessed about them and end up throwing money away, those who read my Cursing Norm post will understand...
The product i finally used to make a simple nameplate sign was the Rutlands Sign Crafter
The kit cost £39.95 + 6.95 delivery and includes both 7/16th and 5/8th letters, includes 164 letters and numbers and can make signs up to 12 inches wide and 36 inches in length. Another added advantage is the inclusion of a couple of guide bushes which have longer stems than my Trend ones also included is a clear poly base plate to take them and they twist on rather than screw on which make them easy to change. There is one 3/8 cove bit included however this only works with the larger letters and looks to have a longer than average shank
The kit is very easy to put together with good instructions in a nutshell you build your sign in between the two holders and attach it via the inclusive cramps
I've done a few practice signs using scraps and will be using it properly on some nice wood at the weekend.
More pics of a finished sign to follow
Hope this helps
Hope this helps
