transatlantic
Boom!
I've recently purchased a low angle block plane (Axminster Rider No. 60 1/2 Low Angle Block Plane) as my introduction to hand planes and things aren't going as 'smoothly' as I'd hoped. There is nothing wrong with tool itslelf, I am just finding it difficult to get a smooth cut. Which is most likely down to me not sharpening it very well. So, I'm wondering if there's a good rule of thumb test for checking to see if a plane blade is sharp before inserting it into the tool? At least that way I can narrow it down to my sharpening, as opposed to something else like wood/technique or something else.
My tests were simple things, like checking to see if it would cut paper cleanly, or removing material from the back of my nail, which it did both with ease. I also tried to shave some hair off my arm, which it didn't manage to do (is that a bad sign?). So I excitedly put the blade in the tool, but was less than happy when I tried to make shavings on a length of thin (1.5 inch) pine (no knots). Although I was able to make nice thin shavings , it took A LOT of effort to push the plane and would often get stuck, and the surface it left wasn't great. The surface wasn't torn, but I'd mostly certainly want to have sanded it afterwards. I also tried flipping the wood to see if I was planing in the wrong direction, but it did'nt help much.
From what I gather, Pine should be one of the easiest woods to plane, and should leave a 'Finish Ready' surface. So I guess my sharpening is bollocks
I followed the technique here https://www.youtube.com/watch?v=eFw--HUkWTc, but with different stones. I used a 1000 grit diamond stone and a 4000 grit water stone. He seems to be able to effortlessly push the blade on hard wood ... like butter.
