Hello all,
I want to make up some of TGV and bead panelling as per the profile below and I was wondering if MR MDF would be suitable? It's a material I am relatively unfamiliar with in so far as machining it goes and my cursory research on it does not fill me with hope.
This profile is taken from some existing timber panelling and with the bits I have, I can get close to it. In fact the only real difference is that the pencil bead will not be recessed below the surface, rather being somewhat flush I would imagine.
It would appear that whilst MDF may not be so bad for TGV, the pencil bead might be an issue when it comes to painting given that it is routed on the surface. It would also appear that MDF will knacker my £200 odd quids worth of brand new Wealden cutters in short order. Now, I don't mind sacrificing a few saw blades while dimensioning the stuff but wrecking the more expensive yet essential cutters is anathema to me.
Is this information correct and would I be better off using a different material?
Thanks,
Michael
Thanks,
Michael
