Router tables - cast iron or MDF & resin?
HomeyJay
12 Jul 2019
Sidcup
I need to get a router table. Yes, I know I can make one for £25 but I don’t have the time to do it.
I’m looking at the Axminster benchtop model with the cast iron fence or the large Kreg Router table (not the benchtop model). Both of these are approx the same price.
I’m pretty torn between these - I’m worried that the small Axminster will eventually become too small and I’m worried that the MDF Kreg will swell up and buckle in my garage workshop!
The fence on the Kreg is amazing though!
I’m using a Triton router by the way.
Can anyone offer any advice regarding the cast iron / MDF tables? Is one better than the other?
D_W
24 Aug 2015
PA, US
What is the surface like on the MDF table? Is it melamine faced?
I no longer have a router table, but made my own (it took only part of a day in teh shop - just 2x4 base and an MDF sheet with jointed boards glued to the bottom to keep it rigid). I made the base quickly, just bolted it together and then planed the top of it into a single plane so it wouldn't cause the top to twist, and bought a table plate. It was a big and cheap router table that worked great.
The MDF swelled by year two with it and I hand planed it flat just checking high spots with a straight edge, resealed the top (with wax) and it never did it again. I've gone away from power tools, or I'd still have it.
If you use your router table to do doors or anything of size, you'll end up wishing for a bigger table or building something to supplement yours later, anyway. I've since gone to building guitars and wish I'd have kept my router table as they're generally template routed around the outside. I bought a tiny cheap table about 24x16 to do the template routing (which isn't the final step, or it wouldn't be suitable) and would never want to do any significant work on it - it would result in more ruined stock and wasted time with that than it would've taken to build one like my original.
ED65
3 Dec 2015
Yeah you do. The simplest router table is a piece of thick ply or MDF with a hole drilled in the middle somewhere, clamped to the edge of a workbench or heavy table. I'm not kidding:
http://www.startwoodworking.com/post/ho ... uter-table
https://www.popularwoodworking.com/proj ... ter-table/
As you can see a functional fence can be an equally simple affair. You'll even see an unmodified 2x4 used as a fence sometimes.
heimlaga
27 Sep 2009
western coast of Finland
I have a very solid large and cast iron table and I am never going to replace it with anything else....... but I honestly think the size of the table is even more important than the material.
Mine weighs around 150 kilos and costed some 300 euros..... plus several weeks of fabrication work. The table and router lift are remnants from a small wood framed line shaft driven spindle moulder from the 1910-s or 20-ies which was beyond the point of reasonable restoration.
sunnybob
wysiwyg
11 Oct 2014
cyprus
Word of warning if you do decided to buy tables and or fences. Different makes have different sized T tracks.
Kreg especially. very few other make clamps or accessories fit into the kreg tracks, so make sure you buy all from the same maker.
My table is home made. its a almost a metre square made of melamine board edged with hardwood to stop breakout. Tracks installed as and where I want them.
My table is not show quality, but it is a brilliant spare table for layout, glue up, and anything else i want a table for when I am not routing. A tiddly bench top table just takes up space.
Brandlin
5 Aug 2015
Flint
I have a Triton router too and i spent some time looking for a table and then built my own. I bought a pre-drilled Kreg plate (resin) with holes for the above table height adjuster. I used an old kitchen cabinet carcass for the table (reinforced with sheet material across the back panel to resist racking).
The top is from a laminated kitchen worktop. Everyone will tell you that is not ideal - and they are right. But it is cheap and in the 3 years I've had it nothing has appreciatively moved or swollen. I'm not attempting to make fine furniture, nor am i checking accuracy to NASA tolerances, so it does me fine.
The fence is made from melamine faced recycled wardrobe doors (split fence adjustable style) and simply clamped tot he table top.
But the table cost me almost nothing apart form the router mounting plate and maybe a day in the workshop. The bit i like best is that the table size is around 1400 x 700. Even when working on some large projects i feel a great deal of security with work pieces on the table... at no point to do i have large amounts of over hang or a potential imbalance in the work. I really don't see how the smaller tables are sufficient when you might be passing large stock over the table and most of it is unsupported.
As always, your needs, available time, resources and skill level will mean you have a different solution...
sunnybob
wysiwyg
11 Oct 2014
cyprus
My Mk1 and Mk2 tables were kitchen countertops.
They are fine if you are using long pieces or planks of wood, but not so good if you use smaller pieces, because the standard counter tops are nowhere near flat if you put a straight edge across it.
Likewise the resin plate. My first was a Kreg and it did buckle slightly. Give Kreg 5 stars for service, they replaced it without question or asking for the old one back.
I dont know if its because of the extreme temperature swings here, but the second one also warped. Again, if youre running 2x2 x 3 ft or more across it, you wont notice it, but if youre into small boxes or model making it does affect the finish.
I've now bit the bullet and bought an incra alloy plate and perforated rings (xmas and birthday present combined :lol: ) and am extremely happy. I wont need another.
Richard_C
17 Oct 2019
Cambridge
I've often thought about a diy router table, simple for occasional non-precision use, and the designs linked from the post above look fine.
What stops me is the on/off switch - with the router running under the table you really do need a way to switch it off quickly if something goes wrong - scrabbling round trying to unplug it seems uncertain and risky.
What do others who have made their own tables do?
Woody2Shoes
Impressive Member
5 Jan 2015
Sussex UK
https://www.charnwood.net/products/prod ... -240v-w026 ?
sunnybob
wysiwyg
11 Oct 2014
cyprus
My NVR switch is on the front leading edge of the table. I can reach it without even looking for it, and if push really comes to shove, i can hit it with my knee. =D>
Helvetica
4 Apr 2011
Ireland
Speaking of Charnwood I just bought the w015 with sliding table (w020 is same without the slider). It’s a cast iron table, dust extraction, gas struts to lift the table, and comes with shims to step out the outfeed. It’s very heavy and well built. I bought it with the NVR switch mentioned above and a collet extension.
Weak point is the fence unfortunately. It is not dead straight out of the box and I will need to make shims to sort it. Once that is done it will be a brilliant router table providing you can leave your router base locked in place, as it’s a faff centering and clamping it.
It’s pretty basic, but the large cast iron table will never warp and when set up right will be great value for money. I think bench top will break your heart.
MikeJhn
Grunkel
2 Sep 2014
Kent mostly and France the rest
Who forgot to put the slot in the bottom rail before assembling the doors then, #-o but does show the table top extension, made by Triton for the T2000 Workbench.
One thing to consider when choosing a top for any machine, how damp is your workshop, makes a difference, if the top is cast iron it will need protecting, the resin top shown in the pic above has not been a problem in the eleven years it's been in the barn.
MadMental
2 Apr 2018
Aberdeen
Hello thier just wondering where you got the sliding table for longer peices of wood it looks perfect for my needs
TRITON
5 Oct 2014
Sunny Glasgow
Ive the triton table and to be totally fair, its bloody rubbish. I only have it as i got the whole thing, base and all for £100 and it kind of does the job, but the top is pressed steel and no way is it rigid enough to be wholly accurate.
In Tritons defence, the base is ok, in that you can collapse it down and takes up little room in storage, is quite robust when set up, but the table doesnt help it perform to standards
Jameshow
4 Oct 2020
Bradford
I would get an offcut of buffalo board.
Flat resin surface and not likely to swell.
You could easily make a fence out of it too.
eBay should have a piece.
Cheers James
Spectric
19 Feb 2015
North Cumbria
Well I have had my Kreg table many years and no problems, the table insert is imperial so you can use Jessem or Incra lifters when you want to, the Axminster I believe is metric to suit the UJK products and so you cannot.
All I have is a simple on/off switch that is very easy to use, this means that doing certain cuts I can reach my end mark, simply turn the router off and wait till it stops before moving the workpiece. I will say the speed control on the triton can be a pain, I use a mirror to see it.
Orraloon
18 Oct 2016
Blue mountains Australia
I have mine built in to the tablesaw wing. This is a great space saver and the home made router fence attaches to the saw fence. I scavenged the switch from an old Aldi router table.
Regards
Keith Cocker
27 Jan 2021
Lancashire
I have the Axminster UJK table and an very pleased with it. I try to stick to metric items for compatibility. Axminster do offer a Melamine top version and of course the larger Cast Iron and Melamine versions.
OldWood
1 Mar 2005
Edinburgh
An NVR switch on the side (ie a push button switch that drops out if the mains is cut) feeding a 13A socket mounted beside the switch and the router plugged in the socket. Something, eg cable tie, round the router to hold the power switch on. Electrically straighforward but an hour's work for a friendly electrician if that's not your bag!!
Back on topic - I was lucky enough to 'recover' a large sheet of faced 1/2 inch SRBP from a skip many years ago. I've never actually checked it for perfect flatness, but it is good for all do. Skips are always wothr keeping an eye on!!
Rob
