Router table inserts
Kane
21 Feb 2006
Do all router table inserts need drilling (to mount your router) or can you get pre drilled versions?
Some manufacturers do drilled plates, but it depends very much on the model of your router.
The bolt spacing on my Triton matched that of a Porter Cable machine, for which there was a pre-drilled Incra Magnaloc plate available, for instance.
Si.
Si.
Is that the original 1/2" triton router you refer to Knapper, older than 5 years?
It's the MOF001 (1400W) model, though I believe the original 2Kw TRA/B001 has the same hole PCD. Not sure about the wee new one...
Si.
