Router table insert drawings
Signal
23 Dec 2002
Thanks Tony, very good of you to have gone to the trouble to redraw
Signal
A
Anonymous
Guest
Roger Sinden":16g1nahf said:
Tony
Is the insert also made from Aluminium? 3mm thick?
Did you make a range with different centre holes for varying cutter diameters?
Roger
Hi Roger
Not sure if I understand you correctly. The main plate is 6mm aluminium sheet whilst the insert plates are 3mm sheet.
I made 6 insert plates with varying hole sizes to accommodate varying diameter cutters
amilford
31 Aug 2004
What holds the inserts in?
Is there not a chance, or liklehood, of them coming out due to vibration?
Not a pretty thought if that does happen and one hits the spinning router bit
