chippy1970":194w0tw1 said:
Hudson Carpentry":1dz5rd1b said:I have never seen one.
What do you need it for? Would a collet extension be enough extra reach?
Agreed, this is the way to do it. Cut have way through from the top using the existing pattern, turn the job over and then use a bottom bearing cutter to do the other half - Rob9fingers":jyw94crz said:The point that you might of missed is that with Jon's suggestion, the part you have already cut becomes the pattern for the second cut.
Bob
Melzy":20k2tr3l said:Thats exactly right flounder!! I'm sure i mentioned at the beginning that the timber was too thick to go straight through??!!!
:lol: :mrgreen:
Melzy":3koiamno said:Hudson Carpentry":3koiamno said:I have never seen one.
never come across a collet 'extension'!?! I am cutting ou a shape for a mirror but the wood is too thick for the cutter i have and need to get through to the other side! {from the same side, as the pattern is only on the front!}
Register today and take advantage of membership benefits.
