Router bit advice please
TJC
25 Aug 2020
Surrey
Hi all, I'm finding it harder to locate the type of router bit I think I need than I expected.
I need to remove around 8mm of material from the underside of a table to recess some metal hairpin leg brackets. I've made up a template of the cut out for routing, but now not sure which bit I need.
I have a 1/4" shaft trim router I'm intending to use for this, so not a proper plunge router, but should be sufficient for such a shallow cut in softwood?
I'm looking for a straight spiral cutter with a bearing at the top of the blade - between blade and machine, but struggling to find what I think I need. Should I just run the smooth part of the bit against the template? Any advice appreciated!
TheTiddles
14 Oct 2007
Wiltshire
Do you have a guide bush for your
router? That’s the better tool for it with a plain straight cutter
A
TJC
25 Aug 2020
Surrey
No, I only have a trim router currently, and no collar. As such I made my template 1:1 rather than oversized, but did that before bit shopping. Will have to rethink if I can't get a bit...
TJC
25 Aug 2020
Surrey
Amazing, thank you. That's no issue, I can lose the pilot hole under where the metalwork will go. I was envisioning something bigger, but that's much better.
DBT85
19 Dec 2015
Pershore, Worcester
For what it's worth, I needed a cove bit for my workshop cladding and it was going to be £15 or something for a branded one. For £60 I got the trend set with 30 odd bits including the one you're after for this I think.
I only had a couple of bits so it made sense to me. Many might never get used and some will wear out. But they can all produce a result to give you options. If you use one a lot then buy the more expensive ones.
Edit :scrub that. On looking at it on amazon it doesn't have the one you want in it.
TJC
25 Aug 2020
Surrey
Just having a look now, all the sets seem to only have bearings at the wrong end for what I need. I got a set of generic Chinese bits with the router and have the same issue, all coves and round overs and trimmers.
It's ordered now anyway, I got the 12mm deep cutter so it's a little more flexible, but this is a specific job I expect to do a fair amount of, so am haply with it...
MikeJhn
Grunkel
2 Sep 2014
Kent mostly and France the rest
This sort of thing will come up over and over again during your woodworking, it may be an idea to get a bush set, I managed to attach the Triton base for the bush's to a 1/4" trim router with a little bit of work, I am sure you could do the same.
  • Like
Reactions: TJC
Pete Maddex
22 Apr 2005
Nottingham
If you're trim router has a round base make up a new template so the whole router fits in.
  • Like
Reactions: TJC
