Honest John
Let me say from the start that m a little bit out of my comfort zone talking or even enquiring about what I understand are called rotary tables. I have a desire to mount my Woodturning scroll chuck onto a rotary table which in turn can be mounted onto the ways of my Woodturning lathe. I intend to attempt some forms of "ornamental" turning to decorate some of my turnings, much along the lines outlined in recent articles in Woodturning magazine. The problems I am finding is that backplanes that bolt to the table and have a threaded nose to screw chucks onto do not seem to be available in the 1 1/4 inch by 8 that I require. I found a rot table on the Warco site that looks very suitable (but is out of stock) and the same manufacturer supplies a backing plate that is designed to fit this table but has a Boxford thread on it, which I understand is 1 1/2 by 8. Presumably some skilled and tooled up artisan could turn this down to the correct size for me ? Now the bit that is really confusing. The back plate sold by Warco has a short morse 2 taper on the back which is supposed to ensure concentricity when fitting to the RT, and it is then bolted with 2 T nuts. The manufacturer says that the fitting is very secure and stable as the whole of the backplate is in contact with the surface of the table. Now to my simple mind it seems likely that if the whole of the backplate is contacting the table, then the taper must be loose enough to allow this to happen. If that's the case then how can it be guaranteed to run true?
Sorry for the long rambling post but like I said the metalworking business is out of my comfort zone. I would be interested if anyone with experience of these devices could aid my understanding.
