Rooting hormone poweder
sammy.se
3 Aug 2014
London
Hi
Can anyone recommend a potent, effective rooting hormone powder?
I've searched online and there are some that call themselves 'natural' and don't call themselves hormones, and others with mixed reviews that call themselves hormones.
It's just for decorative plants, so doesn't need to be organic or food safe, just needs to work.
Cheers!
Sent from my SM-G973F using Tapatalk
sammy.se
3 Aug 2014
London
I plan on cutting offshoots from my oleander plants and using the rooting hormone on them
sammy.se
3 Aug 2014
London
Phil Pascoe":1a34dydu said:
Elf'n safety - there's no hormones in them any more.
Ah really?? No wonder there's so much confusing writing/claims on the boxes.
Any particular brands anyone on here can recommend from experience?
Tris
What am I doing here?
28 Nov 2018
Moreton in marsh
Soluble aspirin as a dip, it's just like salicylic acid which is the main ingredient in most rooting powders. Otherwise soak willow bark overnight and use the water as a dip. Iirc oleander like a bit of warmth from below and gritty medium.
Trainee neophyte
12 Apr 2019
Greece
Oleander is almost indestructible - should take without too much problem, with or without hormones.
I cut mine a bit like rose cuttings, and they took without trouble - I would think too much water would be the only real problem for them - they can tolerate complete absence of water for months, but obviously you want to keep the cuttings damp while they start to sprout.
This is something like the way I did it, except I didn't put them in water and wait for roots - I just shoved them in a pot and crossed fingers...https://homeguides.sfgate.com/grow-olea ... 20981.html
sammy.se
3 Aug 2014
London
Thanks all.
I have general purpose compost and sand. Will that be ok?
Also, should I cut the the branches/offshoots at a ~45 degree angle, or at right angles?
Trainee neophyte
12 Apr 2019
Greece
sammy.se":10u4c0xo said:
Thanks all.
Oliander is native to South Africa, I believe - it lives in deserts, so drainage is vital. Too much good soil makes for too much growth and no flowers - great for the first couple of years, but after that no nitrogen!
As I understand it, you cut the top of the cutting @ 45°, but the bottom flat, purely so you know which way is up when you come to plant them. At least that goes for roses, but I do everything like that to save on making all my plants antipodean. I do a lot of rose cuttings by just shoving a stick in the ground - they seem to quite like the abuse.
Tris
28 Nov 2018
Moreton in marsh
Compost and sharp sand mixed 50:50 will suit them well. Cut tips about 4 inches long, straight across and just below a leaf node. Take off all but the top two leaves and push the cuttings into the compost to about 2/3rds their length. Water well then put the pot in a heated propagator if you have one in a greenhouse, or pop a clear poly bag over the pot and place it on a warm windowsill.
Hope that helps
Tris
Edit to add, there's no harm in cutting at 45 degrees at the bottom, indeed it's essential for hardwood cuttings when there's no leaves for the reasons TN mentioned
sammy.se
3 Aug 2014
London
Thanks! I will give this a go.
Yes! This is what I have - lots of great growth but very little flowers. Does that mean I need to add nitrogen to the soil?
As you can tell, I'm a total beginner at gardening, but keen to learn.
sammy.se
3 Aug 2014
London
Hope that helps
Tris
Great, thank you Tris! very helpful
I will use a poly bag - I don't have a green house - do you mean a warm window sill indoors, or can I leave it in a sunny place in the garden?
Trainee neophyte
12 Apr 2019
Greece
Oleander (sp?) is sneaky - it's flowering is dependent on sunshine levels. When the flowers start, and for how long it flowers, depends on how many hours sunlight it gets in the spring, so it needs wheeling out if the greenhouse at every opportunity. How many flowers you get depends on your fertilizer ratio - I'm not the person to ask as we treat them as weeds - they get completely ignored and abused - used as hedging plants or anywhere you want flowers with zero maintenance and never watering. I would guess less nitrogen and more phosphorus and potassium if it's in a pot. Your plant looks quite young, so it may come into its own later - it will get to the size of a small tree if you let it.
(If that is an olive in the pot next to the oleander, that needs 3:1:2 NPK ratio, and not much of it. You could get away with just giving it nitrogen, or good compost.)
jeremyduncombe
24 Dec 2016
Cranbrook, Kent
I did a trial last year with dozens of plant cuttings, half with “natural” rooting powders, and half with nothing added. The powders made no difference at all to rooting or subsequent growth. I won’t use them again.
Tris
28 Nov 2018
Moreton in marsh
sammy.se":32guw0ki said:
Hope that helps
Tris
Best to keep them indoors at the moment, it's a bit early for what are essentially semi-ripe cuttings but well worth a try with a tender plant.
Try giving it tomato feed at half strength once a week to encourage flowering but stop once it's in flower.
I can't remember if it flowers on old wood or new, but either way the more sun it gets the better it will develop. Helps to ripen the wood, which is also why it is a good idea to stop feeding after flowering.
Bm101
Lean into the Curve
19 Aug 2015
Herts.
Tbh I thought this was about Harry Potter. Only reason I clicked on it.
Bit disappointed tbh.
sammy.se
3 Aug 2014
London
Thanks for all the advice.
It is indeed an olive plant, doing well so far.
sammy.se
3 Aug 2014
London
Phil Pascoe":2ylzjifn said:
Don't forget oleander is poisonous to animals and humans - a single leaf can kill a child.
Didn't know how poisonous these were. Most warnings I've seen are about skin irritation. Luckily no pets or small children here, but good to know - I may not make too many more of these, and try something else like camelia japonica.
