room divider
treena
19 Oct 2005
kent
Hi all
I would like to divide a large room,would like something in wood
Any ideas please.
SketchUp Guru
12 Apr 2005
Rochester, MN USA
Do you have a style in mind? What is the decor like now? Do you want a heavy timber wall or maybe a light shoji screen? Will it be fixed in place or movable? If the latter, where would you store it when it isn't dividing the room? How big is the room? How long and high would the divider need to be? Could it be thick like a book case or thin?
neilc
17 Nov 2005
Ireland
Not everyones cup of tea but have a look here. It can be made with as many panels as you like.
neilc
treena
19 Oct 2005
kent
Thanks Dave R neilc and Newbie_Neil for your replies
Dave, the room is an open plan approx 31' x14' wide, must reach to ceiling- don't want to enclose completely but totally confused as to what thickness etc.
Regards
Treena
frank
10 Sep 2003
cheshire
treena use 3x2 studding screwed to the floor wall and ceiling and skin with plaster board .
frank
Gill
3 Sep 2003
Lincs
I'm a little confused as to exactly what you're after, Treena. Do you want a permanent wall divider or are you after a mobile screen that can be used as needed?
Gill
treena
19 Oct 2005
kent
Frank thank you for your very good idea.
Gill
I would like a permanent wall divider
