Rip or crosscut?
stubtoe
20 Aug 2011
Cheshire
Recently picked up three old(ish) saws off ebay to have a go at sharpening by hand. They weren't expensive so its more about using them to practice on.
So, what have I ended up with?:
I think this is a crosscut (its 22" long, 9-10 tpi):
I think this is a rip (26" long, 7 tpi):
And I think this is another rip (26" long, 7 tpi):
Are my guesses correct?!
Cheers,
Jonny
Sent from my Nexus S using Tapatalk
First one doesn't look to be anything and the other two look like crosscuts to me. How are they cutting?
When you first sharpen saws its a lot easier if they are just dull but all the angles are ok.
Rubbish!
Do the angles look OK?
I think 8-10TPI is a panel Saw, 6-8TPI is a cross-cut and 3-5 TPI a rip saw,
Gary
The last 2 look ok side on, my point is it's easier to re-sharpen a saw thats just dull as opposed to one someone has tried to sharpen, and failed on. Just keep to whats there. Once you have had a bit of practice you can recut new teeth on old saws without too much trouble.
Cheers FF.
Can anyone show me a side on pic of what an actual rip cut handsaw looks like as I'm confused now? ;-)
stubtoe":29sm7vcq said:
Cheers FF.
Don't be so lazy just google it fer crissake!
It says about 2,780,000 results, if that's not enough just go away!
Sent from my Raspberry using dubbleduch
stubtoe":2zaeu8cv said:
Cheers FF.
A rip saw has: large teeth (5 tpi or bigger) no fleam (teeth filed straight across) and very steep rake, say 0 - 3 degrees.
BugBear
