Right tool for the job
Learner Les
16 Mar 2004
Zummerset
I need to cut a number of small pieces of scrap (2 x 0.5 inch ish) using accurate right angles. My armoury of woodwork weapons includes bandsaw, jigsaw, circular saw, various handsaws, mitre saw (hand driven), router (and table).
What do you advise is the best tool for the job ? Any jigs that I could make/use?
ike
24 May 2004
LL,
By the sound of it your mitre saw. If it is what I think it is, the blade is guided in a frame yes?. So this tool will probably give you the most accurate cut.
For a small job as you describe, I'd use the simplest tools - a tenon saw, a try square and a bench block. Good practice for gaining those hand skills!
cheers
Ike
Chris Knight
14 Jan 2004
SE London - NW Kent
I find the best way to deal with more than a few pieces of the size you mention (what is the third dimension by the way - it might be important?) is to nail a couple of small fences to a bit of ply or melamineat right angles and that define two sides of your piece. You can register a back saw of one end of these or if needed nail another couple of bits for a "mitre box" arrangement.
This method removes the need to mark out successive pieces where erros can be introduced.
It is safer and quicker usually than using a power tool.
Alf
22 Oct 2003
Up the proverbial creek
If they need to be really accurate right angles, then a trim on a shooting board after the saw would seem a likely course.
Cheers, Alf
