transatlantic
Boom!
I'm wondering if there is any contraption out there that is like a gas strut or spring, where you can continually adjust (increase or decrease) the force needed to compress the mechanism?
I know that you can buy adjustable gas struts, but once you let the pressure out using the valve, there is not going back.
My thinking was that there might be a gas strut that allowed you to reduce the area containing the gas (when expanded) with a wrench or something, thus allowing you to increase or decrease the force required to compress it.
My other thought is to simply provide some mechaism that allows you to adjust the mechanical advantage point of the gas strut installation.
