A
Anonymous
Guest
Have a valuable piece of old boat bright work or furniture that is broken around the hardware? Yes…my training aid today is an old walnut gunstock from 1936, but these objects are subjects of close inspection by discriminating clients, and require a degree of precision useful for demonstration. Plus, as the techniques and materials are slightly different from other disciplines, it’s also good cross training…. the various woodworking specialties would be well served to cross-fertilize more. Want to learn to bed hardware perfectly? Learn from a stockmaker. Want to achieve perfection with card scrapers on expensive and fragile, highly figured wood? Watch a luthier. Restoring original finishes? A museum furniture conservator. Steambending? A traditional boatbuilder or chairmaker, of course.
The workpiece was severely damaged in a fall, and has other problems. Sometime in its past it acquired a sling swivel that will be removed, a missing chip that will be repaired, several dents, and was stripped and refinished separate from its matching walnut forearm…they are no longer the same color. How do I know the stock is original to the rifle? I can’t be absolutely sure, but examination of the inletting surfaces and comparing them to the forearm show the walnuts to be of the same age and probably from the same supplier…age, species and soil conditions the most important factors in matching color. The firearm in question is one of the first of its model manufactured; has some value, and I’ll restore it…not to new condition, but to appear like a used but well-cared-for representative of its type in excellent original condition.
West System 5:1 boatbuilder’s epoxy when thoroughly mixed has a dab of walnut epoxy dye added. Never use any glue but epoxy in gunstock repairs, with perhaps the exception of using cyano acrylates for filling finish blemishes with clear material. No other glue is nearly as strong, flexible or forgiving. Once a wood surface is contaminated with glue, it can rarely ever be successfully reglued without letting in new wood….I only have one chance to do it right.
Epoxy is applied unthickened to all the broken wood surfaces to be repaired…the main portion of the stock at the breaks is heated gently to thin the applied epoxy for the deepest possible penetration into wood and down cracks with the aid of a thin dentist’s spatula…more epoxy is applied if necessary…
…the pieces are assembled and clamped to cure using a few rubber bands thoroughly waxed first with common paste wax. Cleanup is with a vinegar-dampened rag.
While the breaks at the inletting cure, I attend to the remaining damage…a swivel screw hole and toe chip. I’ll fill these with wood of the exact species, grain and approximate age from my collection of scraps.
From a scrap of identical species, cut and grain I make a 3/8” plug and slice a patch…
…then drill a matching hole with a sharp Forstner bit (you don’t need a pilot for accuracy…simply tap it with a light brass hammer to set…then drill by hand slowly) …file the chip flat…
…and simply rub or drive the patches to a tight fit without clamping and let cure. The screw hole is deeper than the plug patch and was filled with epoxy. Line up the grain exactly. I quit for the day and place the leftover epoxy in the freezer to save it for use tomorrow.
Continued…
Continued…
