replacing the miter slot on a DW744 with a t-slot
ydb1md
6 Apr 2005
Maryland
Has anyone tried replacing the miter slot on a DW744 with a t-slot? A better (larger) saw would come with a proper t-slot but a larger saw in my small shop isn't an option.
To install a t-slot, I'd have to rout a 1-1/8" wide x 3/4" slot in the saws aluminum top and epoxy the t-slot into place.
MikeW
15 Apr 2005
Forest Grove, Oregon USA
Hi ydb,
I had thought of doing this to a Rigid I had. After looking at it and thinking more about it I decided not to do so as I think it would substantially weaken the top.
However, I think the newer version, DW746, now comes with the T-slot. Have you contacted them to see if a new top would bolt in place?
ydb1md
6 Apr 2005
Maryland
Hmmmm . . . good question.
Thanks for the tip!
I love everything about my dw744 except its inability to crosscut wide boards. I put my dw744 on a mobile base to give me storage and better dust collection.
ydb1md
6 Apr 2005
Maryland
I checked and the dw746 is their larger contractor style -- not really interchangeable with the 744. I'm probably going to go ahead and order some t-track and give the modification a "go". It might weaken the top a little but once I epoxy the t-track in place, I'll recoup some of that rigidity. :roll:
MikeW
15 Apr 2005
ydb1md":9krld6m4 said:
...I love everything about my dw744 except its inability to crosscut wide boards...
Hi ydb,
I'm in the same boat but with a small Rigid I bought for remodeling our house several years ago.
fwiw, I use a cross cut sled which even without a t-slot, is wider to the right of the blade by about 6 or so inches and this allows me to crosscut a 10" board without difficulty. Any wider (or too long) I use the sliding miter.
In either case, I use a shooting board to ensure the final product is square (or whatever angle needed). ymmv.
ydb1md
6 Apr 2005
Maryland
Mike,
I can sympathize. I've got a cross cutting sled which has helped a lot. I have to make the occasional 24 or 36" crosscut which is impossible using my miter gauge or the sled. So, I freehand it and go back with a plane or whatever to square up the cut.
Because the saw is direct drive, the runout on the motor arbor doesn't give me a clean edge on my cuts. The list goes on and on . . .
I think I've reached the maximum capability of my saw and it's starting to frustrate me. I'm just not sure what to do given my space constraints. ](*,)
MikeW
15 Apr 2005
Another fwiw...If you have the money I would recommend the Festool saw with the guide.
If that's not in the budget, a homemade guide and circular saw can be very effective. That's what I have for when I need to trim doors or desktops down. A couple swipes with a plane and or sanding smoothes the cut marks right quick.
As for a power tool option, I'm saving my pennies for the Festool option. I borrow one occassionaly and there's not much to clean up after it.
AndyBoyd
22 Nov 2002
Heiloo The Netherlands
I've got a mate who epoxied in a piece of hardwood into the mitre slot , and routed in a T slot into the hardwood, seems to work fine, and it it breaks he just replaces the wood.
I think his T slot is smaller than the standard ones as it takes M4 bolts but it works a treat
Just a thought.
