Quantcast
Replacing tensioning rod for ferm 1007 scroll saw
dingman56
New member
17 Nov 2020
Uk
I have tried to source this part online.
apparently ferm don’t supply spare parts.I believe entry level scroll saws are much the same.
can anyone advise where I can purchase the part.
thanks Dave.
l
AES
18 Feb 2011
Switzerland, near Basel
I don't know this particular saw, sorry, but GUESS it's much the same as many others. Previously some people have apparently used a bicycle spoke with some success - available in various lengths from your local bike shop (or on line). Have a measure up and see if you can find something suitable.
If not I'm sure someone who does know your saw will be along soon.
And IF I'm correct it should also be a simple enough job for any local "handyman/hobbyist" given the necessary dimensions and - presumably - the screw thread info.
HTH
dingman56
New member
17 Nov 2020
Uk
If not I'm sure someone who does know your saw will be along soon.dingman56
HTH
thanks for your advice,I’ll get some threaded rod from my local diy,I should be able to make a new rod.
donwatson
29 Sep 2011
Glenrothes, Fife
Hi, I may have what you need. I was having similar problems with my Aldi saw and asked on here how to fix it.
I was sent various bits and pieces and still have this tension rod as shown in the attached pic.
The length under the little plastic bit at the top is 160mm and the diameter is 0.486mm. Quite a fine thread, could be 5mm but I couldn't say as I can't find the thread gauges.
You can have this if it is any good.
dingman56
New member
17 Nov 2020
Uk
Hi Don.
thanks for your post,
I think the rod may solve my problem “hopefully”if you would send it to me at 654 Huddersfield rd,carrbrook,stalybridge,Cheshire sk15 3py.tel 07581188834.an I will be happy to refund the postage cost.
many thanks
Dave.
donwatson
29 Sep 2011
Glenrothes, Fife
Hi Dave,
All packed up and ready for the post, I should get up there today.
As I said, the rod was one of many pieces I received through this forum (some time ago) and I think it was sent from the Orkney Isles (the donor's name escapes me at the moment). It was sent freely and this is why I am posting to without charge, it helps us all. If it doesn't do the job, hang on to it until someone comes along with the same request, easy eh.
take care
Don W
dingman56
New member
17 Nov 2020
Uk
Hi Dave,
take care
Don W
dingman56
thanks Don
look forward to receiving it,hope it does the job.
stay safe
Dave.
donwatson
29 Sep 2011
Glenrothes, Fife
Safely posted yesterday afternoon and I got a Certificate of Posting just in case. It says delivery within 3 days so I expect you should receive it sometime this week (23rd - 27th Nov)
take care
Don W
