dedee
I have had a B&D 7.2v cordless drill driver for about 10 years now and it is one of my favourites. The batteries are held in the handle rather then in a pack and hence I find it balances well in my hand.
It also has a built in spirit level in the top/back corner which is very useful for holding the drill straight.
Are there any current drills with this feature?
I replaced the nicad batteries 5 years ago and a couple of week ago they gave up the ghost as well. After speaking with the chaps at strikalite.co.uk I decided to replace the nicads with ni-mh batteries as it seemed that my charger was compatible.
The Nimh batteries cost £38.00 (still cheaper then a new drill which I would find clumbersome to use) and although they require an overnight charge rather than the 6 hours on the nicads I have the added benefit of no memory loss and I can still use a favourite tool.
Might be worth others considering if their nicads need replacing.
Andy ( no association with strikalite just a satisfied customer)
edit,
if you do order replacement batteries you should note how they are configured in the tool and where the terminals are.
Eg in my drill there were 6 batteries 2 sitting on top of four with the terminals on two of the bottom four.
edit,
