Afternoon all,
Apologies for another sharpening thread, but I'd like some suggestions for a replacement fine honing stone. For chisels and plane irons.
I currently use a Norton coarse/fine oilstone followed by a small white barbers honing stone I'm borrowing off of my brother, then a strop with autosol. This works well for me.
Problem is, brother wants the stone back (I know right :roll: ) so I want to replace it with something similar. I don't know how fine the stone is, (brother reckons "1000", he uses it for putting a bevel on cut throat razors), it says corundum on the side and when used with water you get a fine grey paste as you work the chisel.
Any thoughts on what would be a good replacement for use between the fine side of a Norton IB-8 oilstone and a loaded strop? Don't have strong preference for oil or water.
Cheers in advance,
Donny
Cheers in advance,
Donny
