Replacement blade for Makita track saw
The very thin ones are aimed at the cordless tracksaws, with corded you can use the thicker blades. This info may help, keeping track offset the same will not impact the tracks rubber.
cutting speed M/secThicknessTPITeethKerf mmHook
Makita44.92477495Offset for using track
B-073531651.62.35202148 ATB2.20.3
B-091671651.01.17601241.520°0.25Cordless plungeSpecialised
B-091731651.01.17601241.520°0.25Cordless plungeSpecialised
B-092601651.61.372012282.223°0.3Specialised
B-092321651.01.960017401.618°0.3Specialised
B-092761651.62.352021482.20.3Specialised
B-092981651.62.35202148 ATB2.20.3Specialised
B-093071651.72.744024562.4-3°0.35SpecialisedAluminium
B-566991651.41.372012282.0015°0.3Cordless plungeSpecialised
B-567081651.252.352021481.850.3Cordless plunge
B-567361651.42.94002660 TCG2.000.3
B-573201651.02.744024561.4523°0.225Cordless plungeEfficut
B-573421651.02.74402456 ATAF1.4523°0.225Cordless plungeEfficutMDF
B-629791651.01.225011251.423°0.2Efficut
Do you happen to know if there is any difference between the B-07353 that my SP6000J came with and the B-09298 I have just bought to replace it? The new one says Specialised as per your table but I wondered if that is juat a rebranding thing
The actual specification of teeth, hook etc are the same, looks like the B-07353 is the entry level blade, the specialised blades are a better range and have better vibration with the Efficut aimed at cordless saws to give better battery life.
It is odd that both the B-07353 and the B-09298 can be purchased for the same price, £45.99 from Makita B-09298 Makita Circular Saw Blade 165mmx20mm 48 Teeth - Part Shop Direct which would suggest just a branding exercise.
Hook angle so you know it is suitable for a tracksaw or at least some mention that it is suitable because the company cannot be bothered to show an image of the actual product being sold. Look at the info provided by that American company, they give a full description and state it is suitable for a tracksaw, not all blades are.
All you have to do is look up the part number in the catalogue below the listing if you really want to know the rake, it’s all there.
