Eric The Viking
- Joined
- 19 Jan 2010
- Messages
- 6,606
- Reaction score
- 62
I'm knocking up a gallows bracket for SWMBO...
... for a hanging flower basket (what did you think I meant?).
I'm using some scraps of rebar - I could just about get it hot enough to bend with a Mapp gas blowlamp, so I've made the hook for the end. So far, so good, but I want to weld on some square plate washers, which will be drilled to take screws to attach the metal to the wooden plate for the wall.
Unfortunately my Square washers are BZP, so I was wondering if there is an elegant way of removing the plating for welding. Obviously I could just have at them with the grinder, but I'd rather keep them as flat and smooth as possible. Could I, for example, remove it with reasonably conc. hydrochloric acid? I have some "brick acid" available.
This can't be an uncommon nuisance so I was wondering what people usually do, apart from just holding their breath or wearing a facemask.
Cheers, E.
PS: this is definitely a "made from scraps" job. Black Hammerite hides a multitude of sins (and welding spatter), and it's functional rather than blacksmith-quality pretty...
Cheers, E.
