Removing the fumes from the workshop
LyNx
27 Jul 2005
swindon
I ask this because my house stinks of contact adhesive and Pre-cat lacquer. The easiest solution is to open the garage door but with it being so cold it's not really an option. If i fitted a fan through the wall, would this remove the fumes. The only problem i see is the smell leaching into next doors house.
Anyone got any ideas or simple solutions
Andy
DaveL
19 Oct 2002
Sudbury, Suffolk
I would think a charcoal filter as used in some cooker hoods may be part of your solution, as you don't want to dump the smell outside.
PowerTool
24 Jul 2005
Darlington
Assuming garage dimensions of 6m x 3m x 2m (l x w x h),even the smallest unit on the link would change the entire volume of air about every 12 minutes,so the flow rate looks good - but personally,I would check to see if the filter would be suitable for the chemicals you are using.
(As respirators come with different types/categories of filter for dealing with different smells)
Otherwise,looks a good price for the kit.
Andrew
