Remove long throw gate lock? (Perry)
marcus
20 Nov 2006
Anyone know how to get these off a door once they are attached? Removing the screws is not enough. It has the black handle/escutcheon thing on the front, and that won't come off either....
marcus
20 Nov 2006
Good question, and I can't find out because I don't know how to get the bolt off either!
Doug71
28 Aug 2016
Yorkshire
I have fitted one or two of those and I'm sure they only screwed on although the ones I fitted didn't have the handle part on the outside.
I do remember you were supposed to use a 26mm bit to drill the hole for the cylinder which is a bit of an odd size, maybe someone used a 25mm or 1" bit and forced the cylinder in so it's got a bit tight?
Fitting instructions here
robgul
Barry Bucknell is my hero
13 Feb 2020
Stratford-upon-Avon
I fitted one just last week - just undo the 4 screws on the black plate of the lock unit - then, using a mallet, tap the brass barrel from the other side and it should come out (the hole size on the fitting instructions is very tight - I had to bash the lock through to fit it) The black handle and brass disc are both just screwed to the face of the door, slipping over the brass barrel - again a tight fit. The retaining "top hat" obviously just unscrews from the foor frame.
The comment about the drill bit size is apposite - I used a 25mm Forstner and "worried it bigger" with the drill and then used a Surform round file to ease the size - but still tight.
