I think he means you will have to close the door as the safety relay switch may not let the motor operate with the door open??
Is the blade sticking on the guard or is debris preventing the blade from turning which may be causing an overload then tripping the fuse.
Have you tried asnother plug socket, in case there is a fault in the socket.
I had a simialr problem with a disc sander which had the factory fitted non replaceable plug. I cut it off and replaced it with new plug, it solved the problem, I think there must have been either a loose connection or broken wiring in the flex.
As you will no doubt have guessed I am not an electrician but I would check all the simple solutions first (as described above) and whittle the possible causes down by a process of elimination.
I would then look at the switch on the saw, checking for dust ingress etc causing intermitent contact. Try the simple options first though.
Good luck.
David
