Found this on the forum , prob not related but thought I would mention it ,if you look at the picture there is a pin/button near a rack and pinion type fitting , could this effect the saw reaching 45’
Hi all, I really like this saw but I have it in bits at the mo to finally sort out the ‘pull’ blade operation once and for all as it’s never been aligned properly (by the way I’ve cracked it). Anyway, decided to take it to bits completely and give it a good overhaul/clean out etc. With regard...
www.ukworkshop.co.uk
Deffo 2nd the angle finder as above or cut two pieces of wood at nearest you can get to 45’ and check to see if it comes out at 90’ ( I’m sure you done that though )
That ref link was from me. I’ve had my tspp250 in complete bits because of several common issues with this machine and, apart from the bl**dy fence, I now have it running properly including the pull blade function.
I‘ve definitely written on this forum about how I solved my own 45 issue (the one you have) but I can’t find it through the search function. I think I may have written it as a PM with another gentleman who PM’d me about his machine…..does anyone know if the site stores our own PM texts?….
The problem is…….I can’t really remember
exactly but I’ll try to give it a go here…..
Basically, my base was not square (on plan) which meant that the load bearing runners (front and back of the machine) were not parallel and so the further you increased the tilt resulted in the runners getting slightly further apart which then noticeably increased the friction AND threw out both the angle and parallel-ness of the blade to the cast iron top. It also meant (I’m struggling to recall exactly sorry) that I was also not able to reach 45 degrees.
Another thing…Those ‘runners’ are plastic toothed paths that carry cogs that take the whole weight of the machine and I eventually found that as the ‘friction’ increased, one of the cogs (can’t remember which) could ’slip’ meaning that, for example, the front runner might have the cog on the 10th tooth but the rear could then be on the 9th/11th…..you can then imagine that the whole mechanism cannot be parallel.
Long story short - managed to square up the base by literally taking it to bits and re drilling holes (including the diagonal bracing) and refitting. This meant that the runners were then parallel and aligned in their respective teeth.
Happy to chat if you want more info (if I can remember, sorry)….PM me perhaps?
