Record power tspp250 dado set
Rigger68
6 Mar 2021
St Helens
Evening all
I’ve bought a used RP tspp250 that’s working pretty good. I’m ordering an INCRA ts-ls fence system for it which should improve it
Has anyone used a dado set on the record power table saw , if yes which brand did you go with ?
I have a Freud blade in it at present that has a 30 hole in the centre , most of the dado sets are for a 16mil arbour
The threaded bar is 10mm
Am I right in thinking I would need a bush from 30mil down to 10mil to make it work safely ?
Regards
Paul
Evening all
Regards
Paul
Did you manage to find one that fits?
I suspect you can fit one.
Record Power make a point of saying they don't support dado blades, but that doesn't mean one won't work on it 🤔
