Hi all
Recently purchased a BS400, great machine but found it liked to wiggle with the wheel kit fitted. Easy solution if you have the same issue is to fit 12mm jacking screws into the threaded holes at the rear of the machine in the base, and a couple of nuts locked together on top so you can wind them down. Now I simply wheel into place, wind these screws down until they touch the floor then give them an extra half turn and no more wiggle.
