Record BS300E Blade support shaft
pops92
10 Oct 2016
Boston Lincolnshire
This is the bit I mean. To replace this you have to buy the whole piece at £16.00 plus delivery. Not just the brass bush that holds the revolving black disc. As the bush as got oval wear I wanted to replace it.
But not at £16.00 So £2.50 Ebay 10mm 150mm brass bar and make one. Attached photos hopefully help with how I achieved it without being able turn 16mm brass bar down with a shoulder.
The brass bush is 10mm dia the black blade disc support shaft is 6mm dia. So drilling on my wood lathe was easy. A fine sanding on the 10mm external part was also easy.
Cleaning the ends was easy with a 12mm round cardide wood lathe cutter, cuts brass so easy. This was so easy to make I decided to make 2 while I was set up.
If anyone wants dimensions of the bush just ask.
