PeteG
My AC400 hasn't worked properly for several months, it's seven years old. Using the remote or on/off button, the extractor would start to spin but then nothing. I decided today just to give it a good clean out with the air compressor, something that worked on my Lidl workshop vac, a good blast around the switch and all was well
Anyway...I take the front panel of the AC400 off, and disconnect the earth wire "A" from the top of the cabinet.
I notice a couple of nuts and a washer "D" inside the cabinet, and two loose earthing wires "B" not connected to anything. The two wires "B" weren't connected to the same bolt in the cabinet as earthing wire "A", as "A" is the other end of one of the wires at "B"...So should these two connectors "B", be bolted on to the same bolt at "C"?
