Rebait or butt
Scotty
29 Jan 2005
EBBW VALE ( South Wales)
Hi all. In the next few days I will be making this for a mate of mine
Sorry its a bad pic, but my question is do I use butt joints or cut a rebait for the boxes, and what are the advantages of both if any. Thanks
SCOTT :D
Scotty
Butt joints should be fine as long as you re-inforce them with biscuits or pocket hole them together. And glue the backs into a rebate for maximum strength.
Hope this helps
Philly :D
It's a slightly awkward design , the one in the pic, with the top overhanging the sides but the base fitting between the sides.
Personally I would have top and bottom fitting between the sides.
Dados are completely unnecessary, butt joints will be fine
Pocket screws and polyurethane glue would be just fine for this application. Alternatively you could use biscuits and pva.
