Ready Mixed Red Mortar Patch/Pointing Repair
Geoff_S
12 Sep 2017
London
Any ideas please?
I know I can mix up mortar with cement dye, but I just wondered if there is a ready mixed option in red that I can use and then keep in my armoury.
For example, I've got a screw that has pulled out of a soft red brick that's taken a bit of brick with it. I just want to fill in the hole and re-drill to put the screw back. So, I don't really need 5kg of mortar and a 1.25kg tub of red powder, if it can be avoided.
I have found the Stonelux product, but it would be a lot cheaper to buy mortar & dye and throw away what I don't use.
Mortar isn't the answer for the problem you describe, Geoff. It sounds like you are trying to get mortar to look like brick, and that will never happen.
I keep a tube of brown frame sealant handy. It matches the red/brown of our bricks fairly well and is quick and easy to apply.
Hi Mike. That was just an example. I have a few broken bricks as well to fix, example in photo. I think this one was painted black at one time.
Geoff S the Black May have been left over from the pollution before smokeless zones came in? If you don’t have or cannot get a matching replacement brick may ?I suggest you drill a linked, as near as possible, series of holes all around the brick then use a chisel or TC mortar router and reverse the brick ! It also appears to be built with black mortar rather than cement.
Epoxy Milliput. Readily available. Comes in a range of colours and will both bind and fill. Can be worked with power tools when set. I have used it to repair terracotta urns in red and also in white form to repair garden statuary. Excellent stuff. Would not use it on a large area.
Thanks AJB, that also looks interesting. What finish does it dry to, the terracotta specifically?
Flat red once given a quick sand or wire brushing. Blends well with terracotta plant pots. I had a very large urn (120cm high) that was blown over in a storm and the top broke off. Repaired it with this. I use it a lot as it is quick and tough and not silly money. I have also used it to repair resin sculptures. It will also take pigments and you can mic colours together (eg add white or black). Adrian
I used coloured mortar to repair a few bricks and it worked fine, in fact I had forgotten about it until I read this so must be a good match!
Your walls look exactly like mine, I live in an Old Victorian school, it has a plinth round and originally had black tuck pointing although there are only bits remaining in areas that are sheltered, I don't fancy re doing it and wouldn't trust the local brickie :rolleyes:
