Freetochat":xp13ljd6 said:
I was looking for better accuracy in this setup as opposed to having the tooling under the timber.
:-s The table of any woodworking machine is normally the reference surface and for profile work it is normal to use the visible face of the timber as the reference face, as in hand woodworking. That being the case you are referencing off the back face of the timber and might be storing up an accuracy problem for the future. The reasons are as folows:
- it is possible that the timbers were planed in more than one session and has slightly different thicknesses, or has even swelled between sessions on the spindle. Even 0.5mm difference can be very noticeable in an intricate cut. It can play havopc when jointing timber
- when running timber underneath a profile cutter there is a slight chance of any warp in the timber resulting in a deep cut in the middle (up-bowed)or ends (down-bowed) of the panel - much reduced by using the hold down, but nonetheless it's there. Conversely an undercut will potentially undercut in the centre (bowed upwards) or at the ends (down bowed), however this can be corrected by making a second, hand pass with something like a short Shaw guard in place rather than a hold-down cramp. You can always take material off, sticking it back on again, however......
- the further "out of the water" the cutter is raised the greater the amount of guarding you need around it. An undercut leaves the timber actually covering the block for much of the pass, so a broken tip will simply fall into the chamber below the table rather than possibly being ejected at arm height.
As you can probably tell I'm an undercutter. The problems I've mentioned don't occur very often, but they
do occur. Choose a working method which avoids the problems to start with and you'll never have to cope with the issues.
May I take this opportunity to recommend Eric Stephensons' excellent book on the spindle moulder,
"Spindle Moulder Handbook" [publ. Stobart-Davis, ISBN 0-85442-031-2 reprinted 1999)? Simply the best book ever published on the subject by an author who was at one time design engineer for Thos. Robinson & Sons of Rochdale, although the previous edition is now a bit out of date about tooling standards. Failing that there is some excellent free information about guarding and safety in publication 18 on the
Spindle Moulder at the HSE website which might be worth looking at.
Regards
Scrit
