RogerS
Most of the CH radiators that I've fitted in the past, have had a sort of hook type contraption on the back which fitted over brackets screwed to the wall - the radiator being dropped in a vertical direction to make them meet. These radiators were also fed from pipes coming up from the floor.
So relatively easy and enough play in the pipe to make the connection.
Now the ones I'm in the process of fitting have two concentric sleeves. The hollow female part is screwed to the wall and the male spigot bolted to the radiator. The radiator is them fitted in a horizontal direction. This works OK for feed pipes that come out from the wall horizontally but I'm puzzling how to connect pipes, that come up vertically from the floor, to the radiator given that there isn't very much play in the pipes.
Any thoughts, guys ?
TIA
TIA
