markturner
Hi, I just took delivery of one of these for one an old Type 15 number 4 bailey I just restored. No problem adjusting the throat to fit, however, I find that the Iron was at the absolute limit of adjustment ( IE the top of the circular cutout in the blade was resting up against the locating screw that secures the cap iron to the frog) when I fitted it and that to get it protrude through the sole, I had to slide the chipbreaker a bit further back up the iron, leaving approx 1.5mm of blade showing as opposed to the .5 of a mm or so I normally leave for a finely set smoothing plane. So it works as it is, but as soon as I need to grind the iron, I am going to start running out of adjustment room. I don't really see this as a problem, as to be honest, the amount of planing that I do, and the number of planes I have got, I don't imagine ever having to actually grind the bevels again. But I was curious as to why the iron did not go in at the other end of the adjustment scale, giving you some slack. I hope I have explained this clearly enough...
I am wondering if I have it set up right, as I would have thought, especially with the addition of the two little tabs, that it should have been a bit less near to max range of movement than it currently is, if I want to move the chipbreaker forward, to ensure the finest shavings, it will mean the iron wont come through the sole enough.
Edit thinking about it, the iron / chipbreaker relationship will remain the same no matter how much you grind away, as it will just slide down the groove in the chipbreaker....
Cheers Mark
Cheers Mark
