In a commercial workshop the cramping up routines are well rehearsed and time is money...so PVA is very popular. PVA glued pieces can be removed from the cramps in 20 or 30 minutes and not long after that will stand a little light working.
Many hobbyists follow the pros and therefore use PVA, but that's not always the best choice. Titebond for example can be awful "grabby", if a tenon is a touch tight it may well grab before it's properly seated, and you might not then be able to fully close up the joint. Or it might take you a couple of minutes to sort out your cramps and cramping pads if you're working single handed, PVA doesn't really give you that time.
In a lot of cases hobbyists might be better off with something like Cascamite. Okay, it's a faff to mix it up, but once that's done you've got all the open time you could want, it's a gap filling adhesive so it can spare your blushes if you've not served a seven year apprenticeship, and it cleans up perfectly with hot water so you won't have the problem of squeeze out messing up your finish.
Good luck!
