Lons
Hi
I'm progressing with my drum sander build but not sure what speed the drum should be running at. I note that the Jet 10-20 specs are 1700 rpm and drum size of 5", i assume they are quoting motor rpm and not speed at the drum peripheral :? .
My motor is 1 ph running at 1425 rpm and drum is not finished yet but should finish about 110 mm made from solid MDF disks so pretty heavy. Will 1425 rpm be about right for the drum shaft or still too fast bearing in mind it may not be perfectly balanced. Probably use a 50mm pulley on the motor but will need to calculate the drum pulley size if I need to change the speed.
Any input will be more than appreciated.
Bob
Bob
