I have a problem with my Record Power PT260. It is a similar product to other planer/thicknessers that were available under different badges.
The rollers stopped working so I checked the back of the machine where the motor drive shaft is connected to a pulley wheel by a belt. Sure enough, the belt was knackered but only in one spot where it touched the drive shaft as the pulley wheel had not been rotating and was also very wobbly. The reason for this was that that the wheel should have been rotating freely on it's metal pin but wasn't and it has damaged the fixing point by turning a round hole into an oval one!
I removed the pin from the wheel, which took a great effort, with the intention on freeing it up and putting it back but the fit is so tight that I think some other fettling is needed. The wheel has a brass lining and the pin is steel (see pic).
Has anyone encountered this problem themselves? What would be the best way remove a little material to make this work while not compromising the roundness of the parts? I thought I could do it on the lathe with some sandpaper.
