Proxxon scroll saw - any feedback?
woodynut
16 Jul 2014
Somerset
Hi
My SIP scroll saw has gone "bang" and I am in the market for a new/second hand machine, the problem is I am in the middle of trying to complete an order so need something quite quickly.
I have seen this at Axminster - Proxxon DSH-2 (sorry - no permissions to post link yet) and wondered if anyone has any experience with this saw?
I have a budget of around £200 so can't quite stretch to a Hegner or Excalibur, would this be a step up from the Jet JSS-16 I wonder?
Any help would be much appreciated.
woodynut":398jeyb2 said:
Hi
If you got on well with the SIP saw why not just get another one.
powertools":52jv1v4f said:
What did you replace it with and how is that going?
I replaced it with a used Rexon VS4003A which arrives tomorrow, but the SIP was right up there too on my favourites list.
    47.7 KB
I hope that works out ok for you.
You have got me building a miniature sanding station based around a sewing machine motor.
:p Good choice. I was on the brink of buying a sewing machine motor and foot pedal for mine when the missus volunteered her old fan.
Proxxon :
Very good durable saw.
No major accidents.
Small flimsy table.
Blade clamps really poor. Making fretwork not very pleasant, but possible.
Quality and cheap (second hand)
Scrollerman":25ad2v7l said:
Hi woodynut.
Some time ago I posted asking about the Proxxon DSH 2 and here's the link :
proxxon-scroll-saws-t63235.html
Within your link Gerard Scanlan says ...
The milling machine likewise will only run for 20 minutes at maximum torque after which it needs to cool down. If you are making really small stuff it will run for longer but you cutter heads cannot even be remotely dulling. So they are accurate machines but they are built for incidental rather than intensive use and they are expensive.
I'd like to offer a different experience with Proxxon kit.
I have had for some while a Proxxon Mill/drill BFW 40/E with which I built up my own mini/micro mill. It has proved absolutely reliable and usable over long periods with no problems at all. I also have both of their machine/drill vices and a compound table all of which which are extremely well made and very accurate.
Incidentally Proxxon products can be bought quite a bit cheaper from http://www.voelkner.de than from the usual UK suppliers. You'll need to either manage in German or use Google Translate.
Had mine for a couple of months now and can't fault it. I am a rank amateur and have nothing to compare it to, but totally happy with it, especially the customer service after a very minor problem with a screw shearing off in the upper clamp. Replacement clamps arrived from the suppler within 24 hours. Brilliant service.
They've also said they've not had any bad feedback about them at all.
