flanajb
- Joined
- 11 Mar 2009
- Messages
- 1,303
- Reaction score
- 11
I have profiled router cutters that I use for cabinet doors. The scribe is done in 2 passes with the tenon running over the top of the cutter.
The cutters I use are here. http://www.wealdentool.com/acatalog/Sash_Bar_54.html
With these cutters the length of the tenon is as long as you want as the cutter passes over the top of the cutter and you are scribing the tenon shoulder.
What I want to know is can you do the same with a spindle moulder ?
If so, what block would I need and is it possible to cut the scribe and the tenon at the same time rather than having to cut the tenon first and then scribe like I am having to do at present when doing them with a router ?
As I am making exterior doors I want to use a through tenon and as such need to have a tenon ~ 100mm in length
