Profile cutter id
LBCarpentry
26 Sep 2012
Leicester
Can any help me Id or find a suitable cutter for the below sash horn profile before I fully give up and make my own - a scary process that I did once and rather not repeat too often if I can help it 😉
Horn is 70mm
Actual moulding is 50mm
Thanks!
Louis
Just man up and grind one up you wimp :ROFLMAO:
I doubt you’ll find anything off the peg that’ll match anyway Louis, get grinding 😎
How many windows have you got to make? If its not too many it would be quicker just to bandsaw and sand the horns
Its only scary because I can never be bothered to grind the limiters and I just go for it with an unbalanced block :ROFLMAO:!
Fine - A lesson for the new apprentice coming up then...templates and routering
Cn;t wait for him to smash out the wrong end - Better order some filler in
Pfft! Limiters are overrated anyway :sneaky:
I've got an old Whitehill block I picked up (Cheap too!) pretty much with horns in mind for it although I haven't actually got around to using it yet, it's a 40mm tall block but unlike your usual Whitehill block this one has a down-cutting shear angle which I would guess would make a far superior finish on horns due to the shearing action across the grain rather than just cleaving it off. I'm just imagining how the old Wadkin EKA/ECA tenoner blocks used to work as they had a shearing angle built into them which made for cleaner cutting.
I imagine it makes grinding the knives a bit more complex again though, as well as having to take the cutting angle into account so the knife is the right shape depth-wise, you would also have to take into account the shear angle so the shape is correct in the height.
I still think these are my favorite cutters though, quirky little thing:
Pocket watches are quirky.
Monacles are quirky.
Belt buckles are quirky
CUTTER BLOCKS SHOULD NOT BE QUIRKY 😂
