A
Anonymous
Guest
Hi
I bought my ferm lathe about a year ago but have only just set it up. I have a couple of problems with it and would be grateful for any advice.
I cant get the drive centre to release from the head stock, I've followed the manufacturers instructions and tapped it from behind using a 6mm bit of dowel but all it did was split the dowel.
Also I think the on/off switch is duff. It was working well then switched itself off, and now it will only run if the on switch is held in which is a bit frustrating. Does anyone know where I can buy a new switch other than from Ferm themselves as that is proving to be a challenge
